[GRASS-dev] Re: [GRASS GIS] #799: Add -o option to muliple import
	of GDAL data
    trac at osgeo.org
    Tue Nov  3 05:53:53 EST 2009
#799: Add -o option to muliple import of GDAL data
  Reporter:  trochtaj     |       Owner:  martinl
      Type:  enhancement  |      Status:  assigned
  Priority:  normal       |   Milestone:  6.4.0
 Component:  wxGUI        |     Version:  unspecified
Resolution:               |    Keywords:  import, multi
  Platform:  Unspecified  |         Cpu:  Unspecified
Comment (by martinl):
 Replying to [comment:4 mmetz]:
 > Replying to [comment:1 martinl]:
 > > Please try r39669 (devbr6). Not sure if to backported it into relbr64
 (it's not bugfix). Probably in GRASS 6.4 we can just set {{{-o}}} as
 default also for {{{v.in.ogr}}}.
 > Just for clarification, the -o flag means "Override dataset projection
 (use location's projection)", same like in r.in.gdal. Thus your suggestion
 to set -o as default means override dataset projection by default?
 No, I am not speaking about CLI, but just about wxGUI dialog for multi-
 import (gdialogs.py).
 Anyway I would to suggest to add '-o' to v.external (to be consistent with
 r.external).
 > The new wxGUI dialog is not consistent with regard to OGR layers and OGR
 datasources, for e.g. *.gpx and *.kml files, datasources are listed as
 layers, although these datasources hold layers themselves. With so many
 different supported OGR formats, I would strongly opt to at least stick to
 the terminology used by OGR in regard to what is a datasource and what is
 a layer to avoid user confusion.
 Right, I am just not getting point in which ways is wxGUI dialog wrong.
 Martin
Ticket URL: <https://trac.osgeo.org/grass/ticket/799#comment:5>
