[GRASS-dev] [GRASS GIS] #803: nviz isosurface drawing often crashes
with segfault
trac at osgeo.org
Fri Nov 6 23:38:08 EST 2009
#803: nviz isosurface drawing often crashes with segfault
Reporter: helena | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.5.0
Component: default | Version: svn-develbranch6
Keywords: isosurface, volume visualization | Platform: Linux
Cpu: x86-64 |
when drawing isosurfaces nviz often crashes for no apparent reason.
sometimes it happens with the first isosurface to be drawn, other time it
happily draws several
and you can keep adding new ones and then it crashes e.g. when it redraws
after changing
polygon size.
Helena
Ticket URL: <http://trac.osgeo.org/grass/ticket/803>
