[GRASS-dev] Unclean exit in 6.5: pgrep issue
Hamish
hamish_b at yahoo.com
Sat Nov 7 22:53:52 EST 2009
Glynn:
> > pgrep itself isn't remotely portable, and shouldn't be used.
duly noted.
Markus:
> Should I revert the change?
I'll work on a replacement asap.
probably start with ps|grep & double checking the IEEE/SUS for portability.
leaving the check off means a few second delay every time you exit, even
if you never started the tcl/tk gui, which is too annoying to let live.
Hamish
