[GRASS-dev] Re: [GRASS GIS] #820: r.in.wms doesn't work in WinGRASS installer distribution
GRASS GIS trac at osgeo.org
Fri Nov 20 18:03:15 EST 2009
  Reporter:  ddalimonte    |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect        |      Status:  new
  Priority:  normal        |   Milestone:  6.4.0
 Component:  Packaging     |     Version:  svn-releasebranch64
Resolution:                |    Keywords:  r.in.wms
  Platform:  MSWindows XP  |         Cpu:  Unspecified
Comment (by hellik):
 Replying to [comment:8 hamish]:
 >  * If it matters I can probably replace bc with the more common awk to
 do the math.
 installing and shipping bc and readline in the wingrass-installer is no
 problem
 >  * No, it really does need to be #!/bin/bash. Variable arrays[n] are not
 present in plain old sh, and if you try without bash you get errors like
 you see in the previous post.
 ah ok. what's about bash in msys, is beyond my knowledge at the moment
 >  * wget can be replaced by curl if it is installed; there's a flag. But
 really we/msys should ship a copy of wget in our windows package. (fwiw
 Mac ships curl not wget)
 osgeo4w ships curl
 >  * r.in.wms for 6.4 is a problematic dead end. The new Python rewrite
 for grass 7 is where the future is. (using new GDAL/OGR drivers if
 possible)
 ok
 >  * I half expect more problems to show up as the shell script version of
 this module has a number of issues, even on Linux.
 > Hamish
 Helmut
Ticket URL: <https://trac.osgeo.org/grass/ticket/820#comment:10>
