[GRASS-dev] Re: [GRASS GIS] #820: r.in.wms doesn't work in WinGRASS
installer distribution
trac at osgeo.org
Fri Nov 20 18:46:07 EST 2009
#820: r.in.wms doesn't work in WinGRASS installer distribution
Reporter: ddalimonte | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: Packaging | Version: svn-releasebranch64
Resolution: | Keywords: r.in.wms
Platform: MSWindows XP | Cpu: Unspecified
Comment (by hellik):
Replying to [comment:10 hellik]:
> > * No, it really does need to be #!/bin/bash. Variable arrays[n] are
not present in plain old sh, and if you try without bash you get errors
like you see in the previous post.
> ah ok. what's about bash in msys, is beyond my knowledge at the moment
in http://sourceforge.net/projects/mingw/files/ there is bash for msys.
i've changed back to #!/bin/bash in r.tileset-script, bash seems to be
recognized because there's no message like "r.tileset: No such file or
directory".
But at all there is again:
r.in.wms layers=global_mosaic mapserver=http://wms.jpl.nasa.gov/wms.cgi
output=wms_global_mosaic
which: wget: unknown command
c:/OSGeo4W/apps/grass/grass-6.4.0svn/scripts/r.in.wms: eval:
line 1: unexpected EOF while looking for matching `''
line 2: syntax error: unexpected end of file
Calculating tiles
c:/osgeo4w/apps/grass/grass-6.4.0svn/scripts/r.tileset:
(standard_in) 2: parse error
Rel. 4.7.1, 23 September 2009
<cs2cs.exe>:
projection initialization failure
cause: Unknown error
program abnormally terminated
ERROR: Problem running cs2cs. <Using from definition: >
ERROR: r.tileset failure
ERROR: wms.request failure
Ticket URL: <https://trac.osgeo.org/grass/ticket/820#comment:11>
