[GRASS-dev] svn help
Markus Metz markus.metz.giswork at googlemail.com
Tue Oct 13 06:27:10 EDT 2009
Jarosław Jasiewicz wrote:
> Hi all
> I tried to add to svn add-ons new module but I did it probably wrong.
> In raster directory I created new dir:
>    svn add r.stream.del
>    svn ci -m "New module" r.stream.del
You can also do
svn mkdir https://svn.osgeo.org/grass/grass-addons/raster/r.stream.del
svn import r.stream.del
svn checkout
https://svn.osgeo.org/grass/grass-addons/raster/r.stream.del r.stream.del
Maybe not the most elegant way to do it, but works for me.
> jarekj at jarekj-desktop:~/src/add-ons/raster$ svn ci -m "New module"
> r.stream.del
> Sending      r.stream.del/Makefile
> Sending         r.stream.del/description.html
> Sending         r.stream.del/global.h
> Sending         r.stream.del/io.c
> Sending         r.stream.del/main.c
> in that moment all files from r.stream.del have been send to
> r.stream.basins (Why??? I was in raster directory when I added new
> subdirectory) and updated that directory.
Maybe there was still some svn information in hidden files within
r.stream.del, depending on how you created that directory (e.g. copying
or renaming r.stream.basins to r.stream.del could cause such behaviour).
Markus M
> Now that directory is corrupted. So I have a problem...
> revision version is 39503 after updating
> Any help?
> greetings ...
> Jarek
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
