[GRASS-dev] [GRASS GIS] #793: Provide breakline (fault line) support for surface interpolation modules
GRASS GIS trac at osgeo.org
Sat Oct 24 09:16:12 EDT 2009
 Reporter:  marisn       |       Owner:  grass-dev at lists.osgeo.org
     Type:  enhancement  |      Status:  new
 Priority:  normal       |   Milestone:  7.0.0
Component:  Vector       |     Version:  unspecified
 Keywords:               |    Platform:  Unspecified
      Cpu:  Unspecified  |
 Current v.surf.* modules do not support breaklines (fault lines). It's
 common in geology and other fields to have line/surface that limits
 interpolated value expansion - interrupts spatial correlation
 (neighborhood influence).
 IMHO breaklines should be taken into account at two times - first when
 choosing data input points for calculation (only points at one side of
 line) and second time - when assigning values for cells - only cells at
 one side of line should receive values.
 I understand that this is longterm goal and it requires lot of discussions
 how it should be implemented. Still it's a wanted feature.
Ticket URL: <http://trac.osgeo.org/grass/ticket/793>
