[GRASS-dev] gmath/gpde Patch for grass6.5 and grass7
Soeren Gebbert
soerengebbert at googlemail.com
Tue Sep 1 06:46:01 EDT 2009
Hello Hamish,
2009/9/1 Hamish <hamish_b at yahoo.com>
> Hi,
> I get two errors compiling 6.5svn.
> The first is because lib/gmath G_math_solvps() fails to return anything
> when it should return int.
> I think I fixed it with r38939, but please check to see if that is correct.
> https://trac.osgeo.org/grass/changeset/38939
Thanks, thats absolutely correct.
> The second is in lib/external/ccmath, eigen() is used but not declared.
> I suppose it needs to be added to lib/external/ccmath/ccmath_grass.h, ??
I will have a look at it this evening.
> This can be caught if you add -Werror-implicit-function-declaration to
> your CFLAGS.
Oh, i forgot this.
Thanks,
Soeren
> cheers,
> Hamish
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20090901/6e62b56f/attachment.html
