[GRASS-dev] Re: sizeof(long) + nviz on reclass map [was: RC5 on Mac
OS X]
Hamish
hamish_b at yahoo.com
Wed Sep 2 08:43:50 EDT 2009
Helena wrote:
> can you please test one additional nviz issue?
> with nc_spm_08 data set, what happens when you run
> g.region rast=elevation
> nviz elevation col=landclass96
> this used to run, but now I get:
> Warning: loading failed
> ERROR:
> landclass96 is a reclass raster, making it regular raster, fixes the
> problem.
> It used to run, so I am not sure whether there is a problem with my
> data set or with my version of GRASS (I am using William's
> grass64 binary).
I can see the same thing on linux 64bit.
The warning is because Gs_loadmap_as_char() in lib/ogsf/Gs3.c returns -2,
which apparently means:
\return -2 if read ok, but 1 or more values
were too large (small) to fit into an unsigned char.
(in which case the max (min) char is used)
return (overflow ? -2 : 1);
... which points to a 32bit/64bit sizeof() snafu ..
Indeed, lib/ogsf/ makes extensive use of "long".
grass65/lib/ogsf$ grep -w long * | wc -l
58
a small C program:
#include <stdio.h>
int main()
printf("sizeof(int) = %d\n", sizeof(int));
printf("sizeof(long) = %d\n", sizeof(long));
printf("sizeof(long long) = %d\n", sizeof(long long));
printf("sizeof(float) = %d\n", sizeof(float));
printf("sizeof(double) = %d\n", sizeof(double));
return 0;
on 32bit i686 linux + gcc:
sizeof(int) = 4
sizeof(long) = 4
sizeof(long long) = 8
sizeof(float) = 4
sizeof(double) = 8
on 64bit amd64 linux + gcc:
sizeof(int) = 4
sizeof(long) = 8
sizeof(float) = 4
sizeof(double) = 8
which would be a great theory if it worked on 32bit linux, but of
course it crashes there too, so dunno.
Hamish
