[GRASS-dev] see the picture in vdigit with wingrass
Hamish
hamish_b at yahoo.com
Thu Sep 3 03:48:17 EDT 2009
Quentin wrote:
> >> i try to work grass with windows (wingrass). the version is
> >> grass6.3.
If you can manage to install a 6.4.0rc, many things may be fixed.
> >> I can see the picture but when I try to see the same
> >> picture in v.digit I have the white screen. i can see vector
> >> that i draw but not the pcture. i don't have error message.
Hamish:
> > maybe it is a zooming off-page / computational region problem?
> > try "g.region rast=picture1 at my_mapset" first
> i try this instruction but i have th e problem.
> when i try
> v.digit -n map=name_of_vector bgcmd="picture1 at my_mapset"
> i have the white screen and
(bgcmd needs to have the d.rast part too, not just a map name)
> v.digit -n map=name_of_vector bgcmd="d.rast picture1 at my_mapset"
> i hace the error message
> d.rast picture1 at my_mapset is not a coorect instruction
are you running this from the GUI or from the command prompt?
In the tcltk gis.m GUI output window + [Run] box thing the command
needs to be quoted in Tcl style:
v.digit -n map=name_of_vector bgcmd={d.rast picture1 at my_mapset}
hope it helps,
Hamish
