[GRASS-dev] wxGUI Help
Martin Landa landa.martin at gmail.com
Fri Sep 4 13:38:56 EDT 2009
2009/9/4 Martin Landa <landa.martin at gmail.com>:
>> Also, Would it be possible to generate an image or formatted text showing
>> the GUI tree for the raster, vector and other commands - no matter
>> how logically you organize the commands there will be users with their
>> own interpretations struggling to find modules. Currently, I recommend
>> to type the command into Cmd and hit Enter, but one needs to know the
>> command
>> for that.
> Agreed, should not be so much work to implement it (probably could be
> reported as wish in trac).
see r38973 - menu item 'Help->Show menu tree'
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
