[GRASS-dev] Re: [GRASS GIS] #65: WinGRASS: Starting up gis.m &
hangs (probably on g.region)
trac at osgeo.org
Thu Sep 10 17:23:08 EDT 2009
#65: WinGRASS: Starting up gis.m & hangs (probably on g.region)
Reporter: pvbgis | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: closed
Priority: major | Milestone: 6.3.1
Component: default | Version: 6.3.0
Resolution: fixed | Keywords: wingrass
Platform: MSWindows XP | Cpu: Unspecified
Changes (by cnielsen):
* status: reopened => closed
* resolution: => fixed
Comment:
On the latest
[http://grass.osgeo.org/grass64/binary/mswindows/native/WinGRASS-6.4.0SVN-
r38959-1-Setup.exe 6.4.0svn-r38959] this problem is fixed.
g.gui tcltk &
Or:
g.gui wxpython &
both work when grass is opened with the msys icons. With the cmd window
startup method, closing the GUI closes grass completely (no more terminal)
so the problem doesn't exist here either.
It may never have been fixed for the grass63 installer but it is
deprecated now anyway so I'm marking this as fixed.
Ticket URL: <http://trac.osgeo.org/grass/ticket/65#comment:14>
