[GRASS-dev] Re: [GRASS GIS] #598: MacOS X / OpenGL and Wxpython incompatible
GRASS GIS trac at osgeo.org
Fri Sep 11 00:15:46 EDT 2009
  Reporter:  vince   |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect  |      Status:  new
  Priority:  normal  |   Milestone:  6.4.0
 Component:  NVIZ    |     Version:  svn-trunk
Resolution:          |    Keywords:
  Platform:  MacOSX  |         Cpu:  OSX/Intel
Comment (by cmbarton):
 I have compiled GRASS 6.5 and 6.4 and it all works fine, including nviz
 and the wxpython 3D.
 Here is what works for me with the newest versions. Note that this is
 compiled in 64 bit. I'm using OS X 10.5.8, the current frameworks by
 William Kyngesburye, and Activstates TclTk 8.5 for aqua. Please check to
 see if this works for you too.
 Configure string:
 ./configure --with-freetype --with-freetype-
 includes="/Library/Frameworks/FreeType.framework/unix/include/freetype2
 /Library/Frameworks/FreeType.framework/unix/include" --with-freetype-
 libs=/Library/Frameworks/FreeType.framework/unix/lib --with-
 gdal=/Library/Frameworks/GDAL.framework/Programs/gdal-config --with-proj
 --with-proj-includes=/Library/Frameworks/PROJ.framework/unix/include
 --with-proj-libs=/Library/Frameworks/PROJ.framework/unix/lib --with-proj-
 share=/Library/Frameworks/PROJ.framework/Resources/proj --without-geos
 --with-jpeg-
 includes=/Library/Frameworks/UnixImageIO.framework/unix/include --with-
 jpeg-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib --with-png-
 png-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib --with-tiff-
 tiff-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib --without-
 postgres --without-mysql --with-odbc --with-sqlite --with-sqlite-
 libs=/Library/Frameworks/SQLite3.framework/unix/lib --with-sqlite-
 includes=/Library/Frameworks/SQLite3.framework/unix/include --with-fftw-
 includes=/Library/Frameworks/FFTW3.framework/unix/include --with-fftw-
 libs=/Library/Frameworks/FFTW3.framework/unix/lib --with-x --with-cxx
 --with-opengl=aqua --without-readline --prefix=/Applications/GRASS
 --enable-macosx-app --with-python=/usr/bin/python-config --with-
 wxwidgets=/usr/local/lib/wxPython-unicode-2.8.9.2/bin/wx-config --with-
 tcltk-includes="/Library/Frameworks/Tcl.framework/Headers
 /Library/Frameworks/Tk.framework/Headers
 /Library/Frameworks/Tk.framework/PrivateHeaders" --with-macosx-
 archs="i386,x86_64"
 **** IMPORTANT: after configure, but BEFORE make, edit
 include/make/platform.make to change the line from
 TCLTKLIBS           =  -ltk   -ltcl
 to
 TCLTKLIBS = -framework Tcl -framework Tk
 then run make and sudo make install
 Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/598#comment:24>
