[GRASS-dev] Network Analysis
Markus Metz
markus.metz.giswork at googlemail.com
Mon Sep 14 06:31:24 EDT 2009
Hi Daniel,
nice job you did with the new network analysis modules! Obviously you
have understood dglib, this is very good news :-) Maybe you could have a
look at BUG2 [1] for network analysis? I have an idea but am not sure if
it is correct. There is also a wish to have costs as type double instead
of int, but it seems that this means a lot of modification of dglib.
What do you think?
Regarding the new modules, I have a suggestion: all modules use
nlines = Vect_get_num_lines(&In);
for (i = 1; i <= nlines; i++) {
int type = Vect_read_line(&In, Points, Cats, i);
or similiar. Vect_read_line exits with a fatal error for dead lines, adding
if (!Vect_line_alive(&In, i))
continue;
before Vect_read_line() would avoid that. See e.g. Vect_copy_map_lines()
in Vlib/map.c.
Best,
Markus M
[1] https://trac.osgeo.org/grass/ticket/584
Daniel Bundala wrote:
> Hello everyone,
> during the past few months I worked on a Google Summer of Code project
> to extend GRASS network functionality. I sent a final summary report
> to OSGeo GSoC mailing list. Since there are people not subscribed to
> that mailing list who might be interested in the project, I was asked
> to sent the report to this list and stress the paragraph on inclusion
> into the main GRASS....
> The goal of my project, which I have successfully accomplished, was to
> implement modules for network analysis. This includes basic methods
> such as: strongly and weakly connected components, minimum spanning
> trees, bridges and articulation points as well as more complicated and
> advanced tools for calculating maximum flow, minimum cut or
> k-connectivity in a network. There is also a bunch of modules finding
> shortest paths in a network. One module computes all-pairs shortest
> paths, another finds the shortest paths between nodes and a given set
> of features and, finally, there is a module that finds fastest paths
> using timetables.
> All module follow standard GRASS conventions. This holds both for the
> code and user interface. I also tried to make the modules as flexible
> as possible -- each of them accepts a wide range of parameters, which
> can alter the behaviour. Moreover, the algorithms are separated from
> the modules and stored in a library. An effect of this is that the
> modules are mostly straightforward (only exception is v.net.timetable)
> and consist only of reading the input, calling a few library functions
> and writing an appropriate output. Another advantage of this approach
> is that the “core functionality” can be reused in other modules. Much
> more about the modules (a lot of pictures and link to code) can be
> found at mi wiki: http://grass.osgeo.org/wiki/GSoC_Network_Analysis.
> I have learnt a lot about GRASS and its vector architecture however
> this was my second summer working on vector modules. This was the
> first time I really had to work with attributes data and so I have
> learnt a lot about the data management. At the beginning, I found the
> system with many layers and multiple categories a bit complicated but
> in the process of developing the modules I have discovered its
> expressiveness and enormous power.
> At the moment, my code is stored in add-ons repository. I already know
> about several people using the modules for their work and I hope that
> the modules will eventually be integrated into the main distribution
> and bring eternal joy to all GRASS users.
> Finally, I want to thank my mentor (Wolf Bergenheim), OSGEO project
> coordinator (Wolf Bergenheim) and the whole GRASS, OSGeo and Google
> Summer of Code community for support, T-shirts and for doing a
> wonderful job! Thanks!
> Daniel
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
