[GRASS-dev] r.watershed question
Markus Metz
markus.metz.giswork at googlemail.com
Thu Sep 17 15:24:29 EDT 2009
Michael Barton wrote:
> r.watershed can produce a map of "drainage directions".
> The values of a direction map are in the range of -8 - +8
> Can someone tell me what these numbers refer to? That is, what
> direction is 3 or -3? I've tried to run some correlations against an
> aspect map and am not getting meaningful results yet.
r.watershed drainage direction is encoded as steps of 45 degree counted
counterclockwise from East: 1 = 45 degree from East = NE, 2 = 90 degree
from East = N etc. Negative values indicate flow towards a cell with
undefined (NULL) elevation and thus undefined flow accumulation. Cells
with undefined elevation are either outside the current region or
elevation for that cell is not available (MASKed or NULL).
Correlations against an aspect map may not work because in r.watershed
water can flow uphill (hydrological DEM correction on-the-fly). MFD does
additional corrections to flow direction according to maximum flow,
visible in the difference between SFD and MFD basins (e.g. for
elev_lid792_1m in the North Carolina sample dataset).
Hope that helps,
Markus M
