[GRASS-dev] r.watershed question
Michael Barton
Michael.Barton at asu.edu
Thu Sep 17 16:08:15 EDT 2009
Thanks much. I swear I looked at the help file but somehow did not see
this.
I appreciate your help.
Michael
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Arizona State University
Phone: 480-965-6262
Fax: 480-965-7671
www: www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Sep 17, 2009, at 12:14 PM, Jarek Jasiewicz wrote:
> negative numbers are assigned to cells which contribute outside area
> numbers refers to direction:
> 3 | 2 | 1
> 4 | 0 | 8
> 5 | 6 | 7
> you can find direction by multipy the number by 45 (against east CCW)
> from help page:
> /drainage/
> Output map: drainage direction. Provides the "aspect" for each cell
> measured CCW from East. Multiplying positive values by 45 will give
> the direction in degrees that the surface runoff will travel from
> that cell. The value 0 (zero) indicates that the cell is a
> depression area (defined by the depression input map). Negative
> values indicate that surface runoff is leaving the boundaries of
> the
> current geographic region. The absolute value of these negative
> cells indicates the direction of flow.
> Jarek
> Michael Barton pisze:
>> r.watershed can produce a map of "drainage directions".
>> The values of a direction map are in the range of -8 - +8
>> Can someone tell me what these numbers refer to? That is, what
>> direction is 3 or -3? I've tried to run some correlations against an
>> aspect map and am not getting meaningful results yet.
>> Thanks
>> Michael
>> C. Michael Barton
>> Phone: 480-965-6262
>> Fax: 480-965-7671
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
