[GRASS-dev] Re: bundling wxpython - solves 6.4 digitizer problem
William Kyngesburye
woklist at kyngchaos.com
Mon Sep 21 17:45:14 EDT 2009
that's strange - the installer should have put the whole wx package
in /usr/local/lib/libwxpython-unicode-2.8.10.1, and only the
wxredirect.pth in site-packages.
Putting all the python parts in site-packages, and the wx libraries
in /usr/local/lib, was the old way their installers worked.
Are you sure this isn't the wxpython you compiled?
try this, I'm curious (adjust the path if needed, I'm guessing):
otool /Library/Python/2.5/wx-2.8-mac-unicode/wx/_core_.so
There should be a path to libwx_macud-2.8.0.dylib in the output.
On Sep 21, 2009, at 4:14 PM, Michael Barton wrote:
> Inside site_packages, the only think I've got is:
> -a folder named wx-2.8-mac-unicode that has all the wxpython stuff
> in it,
> -a file called wxpython-2.8.10.1-py2.5.egg-info, and
> -a file called wxversion.py
> Michael
> ______________________________
> C. Michael Barton
> Director, Center for Social Dynamics & Complexity
> Professor of Anthropology, School of Human Evolution & Social Change
> Arizona State University
> Tempe, AZ 85287-2402
> USA
> voice: 480-965-6262; fax: 480-965-7671
> www: http://csdc.asu.edu, http://shesc.asu.edu
> http://www.public.asu.edu/~cmbarton
> On Sep 21, 2009, at 2:00 PM, William Kyngesburye wrote:
>> What about wxredirect.pth?
>> On Sep 21, 2009, at 3:23 PM, Michael Barton wrote:
>>> I've only got wxversion.py, no wx.pth
>>> Michael
>>> C. Michael Barton
>>> USA
>>>>>> Also, make sure there is only one wx path file in your site-
>>>>>> packages,
>>>>>> that points to your only installed wx.
>>>>> How can I check this path?
>>>> Look for a file along the lines of:
>>>> .../python2.5/site-packages/wx.pth
>>>> This will contain the (possibly relative) path of a directory to be
>>>> added to the Python module path.
>>>> E.g. I have:
>>>> $ cat /usr/lib/python2.5/site-packages/wx.pth
>>>> wx-2.8-gtk2-unicode
>>>> This causes the directory
>>>> /usr/lib/python2.5/site-packages/wx-2.8-gtk2-unicode
>>>> to be added to the module path, so "import wx" loads the file
>>>> /usr/lib/python2.5/site-packages/wx-2.8-gtk2-unicode/wx/
>>>> __init__.py
>>>> However: I'm not sure whether wx.pth is actually relevant if
>>>> wxversion
>>>> is used, as it modifies sys.path itself.
>>>> Glynn Clements <glynn at gclements.plus.com>
>>> grass-dev mailing list
>>> grass-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/grass-dev
>> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
>> http://www.kyngchaos.com/
>> "Those people who most want to rule people are, ipso-facto, those
>> least suited to do it."
>> - A rule of the universe, from the HitchHiker's Guide to the Galaxy
"I ache, therefore I am. Or in my case - I am, therefore I ache."
- Marvin
