[GRASS-dev] Re: bundling wxpython - solves 6.4 digitizer problem
Michael Barton
Michael.Barton at asu.edu
Mon Sep 21 18:10:57 EDT 2009
I did not compile these. I've never compiled wxpython. These are
downloaded from the wxpython site as binaries and installed with their
packager.
They changed where the wxpython stuff is located several versions
back. It is now located in /usr/local/lib/wxpython[version number].
Inside of this is ../lib/Python2.5/site-packages/wx-2.8-mac-unicode/wx
and ../lib/Python2.5/site-packages/wx-2.8-mac-unicode/wxpython
Michael
______________________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Arizona State University
Tempe, AZ 85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
www: http://csdc.asu.edu, http://shesc.asu.edu
http://www.public.asu.edu/~cmbarton
On Sep 21, 2009, at 2:45 PM, William Kyngesburye wrote:
> that's strange - the installer should have put the whole wx package
> in /usr/local/lib/libwxpython-unicode-2.8.10.1, and only the
> wxredirect.pth in site-packages.
> Putting all the python parts in site-packages, and the wx libraries
> in /usr/local/lib, was the old way their installers worked.
> Are you sure this isn't the wxpython you compiled?
> try this, I'm curious (adjust the path if needed, I'm guessing):
> otool /Library/Python/2.5/wx-2.8-mac-unicode/wx/_core_.so
> There should be a path to libwx_macud-2.8.0.dylib in the output.
> On Sep 21, 2009, at 4:14 PM, Michael Barton wrote:
>> Inside site_packages, the only think I've got is:
>> -a folder named wx-2.8-mac-unicode that has all the wxpython stuff
>> in it,
>> -a file called wxpython-2.8.10.1-py2.5.egg-info, and
>> -a file called wxversion.py
>> Michael
>> C. Michael Barton
>> USA
>> On Sep 21, 2009, at 2:00 PM, William Kyngesburye wrote:
>>> What about wxredirect.pth?
>>> On Sep 21, 2009, at 3:23 PM, Michael Barton wrote:
>>>> I've only got wxversion.py, no wx.pth
>>>> Michael
>>>> C. Michael Barton
>>>> Change
>>>> USA
>>>>>>> Also, make sure there is only one wx path file in your site-
>>>>>>> packages,
>>>>>>> that points to your only installed wx.
>>>>>> How can I check this path?
>>>>> Look for a file along the lines of:
>>>>> .../python2.5/site-packages/wx.pth
>>>>> This will contain the (possibly relative) path of a directory to
>>>>> be
>>>>> added to the Python module path.
>>>>> E.g. I have:
>>>>> $ cat /usr/lib/python2.5/site-packages/wx.pth
>>>>> wx-2.8-gtk2-unicode
>>>>> This causes the directory
>>>>> /usr/lib/python2.5/site-packages/wx-2.8-gtk2-unicode
>>>>> to be added to the module path, so "import wx" loads the file
>>>>> /usr/lib/python2.5/site-packages/wx-2.8-gtk2-unicode/wx/
>>>>> __init__.py
>>>>> However: I'm not sure whether wx.pth is actually relevant if
>>>>> wxversion
>>>>> is used, as it modifies sys.path itself.
>>>>> Glynn Clements <glynn at gclements.plus.com>
>>>> _______________________________________________
>>>> grass-dev mailing list
>>>> grass-dev at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/grass-dev
>>> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
>>> http://www.kyngchaos.com/
>>> "Those people who most want to rule people are, ipso-facto, those
>>> least suited to do it."
>>> - A rule of the universe, from the HitchHiker's Guide to the Galaxy
> "I ache, therefore I am. Or in my case - I am, therefore I ache."
> - Marvin
