[GRASS-dev] Re: bundling wxpython - solves 6.4 digitizer problem
William Kyngesburye
woklist at kyngchaos.com
Mon Sep 21 18:29:32 EDT 2009
I think we're converging on understanding what the other means ;)
For that wxredirect.pth file, that should be in /Library/Python/2.5/
site-packages. No other wx files or folders whould be there, all as
you say in /usr/local/lib/wxpython-unicode-[version].
On Sep 21, 2009, at 5:10 PM, Michael Barton wrote:
> I did not compile these. I've never compiled wxpython. These are
> downloaded from the wxpython site as binaries and installed with
> their packager.
> They changed where the wxpython stuff is located several versions
> back. It is now located in /usr/local/lib/wxpython[version number].
> Inside of this is ../lib/Python2.5/site-packages/wx-2.8-mac-unicode/
> wx and ../lib/Python2.5/site-packages/wx-2.8-mac-unicode/wxpython
> Michael
> ______________________________
> C. Michael Barton
> Director, Center for Social Dynamics & Complexity
> Professor of Anthropology, School of Human Evolution & Social Change
> Arizona State University
> Tempe, AZ 85287-2402
> USA
> voice: 480-965-6262; fax: 480-965-7671
> www: http://csdc.asu.edu, http://shesc.asu.edu
> http://www.public.asu.edu/~cmbarton
> On Sep 21, 2009, at 2:45 PM, William Kyngesburye wrote:
>> that's strange - the installer should have put the whole wx package
>> in /usr/local/lib/libwxpython-unicode-2.8.10.1, and only the
>> wxredirect.pth in site-packages.
>> Putting all the python parts in site-packages, and the wx libraries
>> in /usr/local/lib, was the old way their installers worked.
>> Are you sure this isn't the wxpython you compiled?
>> try this, I'm curious (adjust the path if needed, I'm guessing):
>> otool /Library/Python/2.5/wx-2.8-mac-unicode/wx/_core_.so
>> There should be a path to libwx_macud-2.8.0.dylib in the output.
>> On Sep 21, 2009, at 4:14 PM, Michael Barton wrote:
>>> Inside site_packages, the only think I've got is:
>>> -a folder named wx-2.8-mac-unicode that has all the wxpython stuff
>>> in it,
>>> -a file called wxpython-2.8.10.1-py2.5.egg-info, and
>>> -a file called wxversion.py
>>> Michael
>>> C. Michael Barton
>>> USA
>>> On Sep 21, 2009, at 2:00 PM, William Kyngesburye wrote:
>>>> What about wxredirect.pth?
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"The beast is actively interested only in now, and, as it is always
now and always shall be, there is an eternity of time for the
accomplishment of objects."
- the wisdom of Tarzan
