[GRASS-dev] wxGUI issue after typing d.* commands into cmd
Helena Mitasova
hmitaso at unity.ncsu.edu
Tue Sep 22 11:07:29 EDT 2009
Martin, Michael,
you may have some advice or fix on this:
after accidentally typing any d.* command (e.g. d.legend)
into Cmd line an error message pops up
layer type <rastleg> not supported yet
This message is causing two major problems:
1. even if you delete the offending d.* command and use the
appropriate icon
provided for the task the error message keeps popping up and the best
way
to get rid of various erratic behaviors is to quit GRASS. This happens
with d.rast and other d.* commands as well.
Would it be possible to manage this situation in a better way?
2. The message itself is very confusing - people think that you simple
cannot draw a legend because this capability has not been implemented
yet.
How about changing it to something
"d.* commands should be run from GUI, see wxGUI Help"
or maybe others can come up with something better?
Helena
