[GRASS-dev] default GUI
Martin Landa landa.martin at gmail.com
Sat Sep 26 14:52:35 EDT 2009
2009/9/26 Markus Neteler <neteler at osgeo.org>:
>> Initially I was not thinking about wxGUI as default for 6.4.0. Few
>> days ago some of devs/users started speaking about that. That's not up
>> me to decide, I cannot compare stability/usability of wxGUI versus
>> TCL/TK GUI. One of problem of the wxGUI are extensions which are not
>> separated from the main program (e.g. local copy of PseudoDC is used
>> when vector digitizer is available otherwise PseudoDC from wxPython is
>> used which can cause problems sometimes, etc.).
> What do you think about Glynn's latest comment?
unfortunately till November I have no time for the wxGUI development.
I will be happy if someone will improve the current design as Glynn
mentioned.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
