[GRASS-dev] vtkGRASSBridge update
Soeren Gebbert soerengebbert at googlemail.com
Sat Sep 26 12:36:27 EDT 2009
Hello Ben,
2009/9/26 Benjamin Ducke <benjamin.ducke at oxfordarch.co.uk>:
> Great stuff indeed, Soeren!
Thanks a lot. I hope this code will help to do something useful in the future.
>> Curiosity: how much faster is this compared to v.delaunay or likewise?
> To me, it's not so much the speed that matters but functionality.
> VTK's 2D Delaunay has a very useful "alpha" threshold setting to constrain
> the triangle (by maximum triangle size).
> In addition, it's capable of fitting a plane of reference through the data
> points and does not assume that they lie perfectly in the X-Y plane.
> This gives much better results for point clouds that describe e.g. micro relief
> on a slope.
> You can try this already, even without the VTK bridge: just export some
> 3D points to VTK, load into ParaView (3.6) and choose Delaunay 2D from
> the "Filter" menu.
> Now, if only we had a simple way of getting VTK data back into GRASS...
This is work in progress .... there will be of course a
vtkGRASSVectorPolyDataWriter()
in ... some ... weeks. :)
Best regards
Soeren
> Ben
>> Markus
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
> Benjamin Ducke
> Senior Applications Support and Development Officer
> Oxford Archaeological Unit Limited
> Janus House
> Osney Mead
> OX2 0ES
> Oxford, U.K.
> Tel: +44 (0)1865 263 800 (switchboard)
> Tel: +44 (0)1865 980 758 (direct)
> Fax :+44 (0)1865 793 496
> Files attached to this email may be in ISO 26300 format (OASIS Open Document Format). If you have difficulty opening them, please visit http://iso26300.info for more information.
