[GRASS-dev] Re: wxGUI: zoom-to missing in RGB mode
Markus Neteler
neteler at osgeo.org
Tue Sep 29 11:06:08 EDT 2009
On Tue, Sep 29, 2009 at 5:02 PM, Markus Neteler <neteler at osgeo.org> wrote:
> Hi,
> when adding an RGB image to the wxGUI, it is not possible to
> get the Zoom to selected map(s)" function in the right-mouse-button
> dialog.
> Would it be possible to add this to the context menu?
Additional observation (bug): When loading an RGB set into the wxGUI,
it contains the extension .red in the "map" name which should be omitted
(stripped off) since a RGB composite is shown - currently it is a bit
misleading...
thanks
Markus
