MN:
> Additional observation (bug): When loading an RGB set into
> the wxGUI, it contains the extension .red in the "map" name which
> should be omitted (stripped off) since a RGB composite is shown
> - currently it is a bit misleading...
I saw the same today and wondered if that layer line could be \n 'd
to 3 lines long somehow.
Hamish
