[GRASS-dev] Re: wxGUI: zoom-to missing in RGB mode
Martin Landa landa.martin at gmail.com
Tue Sep 29 14:25:03 EDT 2009
2009/9/29 Markus Neteler <neteler at osgeo.org>:
> Additional observation (bug): When loading an RGB set into the wxGUI,
> it contains the extension .red in the "map" name which should be omitted
> (stripped off) since a RGB composite is shown - currently it is a bit
> misleading...
try r39337 (also backported to devbr6). I would not suggest backport to relbr64.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
