[GRASS-dev] Re: wxGUI: zoom-to missing in RGB mode
Markus Neteler neteler at osgeo.org
Tue Sep 29 15:12:15 EDT 2009
On Tue, Sep 29, 2009 at 8:25 PM, Martin Landa <landa.martin at gmail.com> wrote:
> Hi,
> 2009/9/29 Markus Neteler <neteler at osgeo.org>:
>> Additional observation (bug): When loading an RGB set into the wxGUI,
>> it contains the extension .red in the "map" name which should be omitted
>> (stripped off) since a RGB composite is shown - currently it is a bit
>> misleading...
> try r39337 (also backported to devbr6). I would not suggest backport to relbr64.
thanks for both! My basic problem is that I cannot launch wxGUI for
several weeks meanwhile... so no testing possible.
The old map pops up, then closes and that's it. In strace I see a
--- SIGCHLD (Child exited) @ 0 (0) ---
Location manager and such work!
Using 6.4.0svn, recompiled from scratch now, and
rpm -qa | grep wx | sort
lib64wxgtk2.8-2.8.9-3.2mdv2009.1
lib64wxgtk2.8-devel-2.8.9-3.2mdv2009.1
lib64wxgtkgl2.8-2.8.9-3.2mdv2009.1
lib64wxgtku2.8-2.8.9-3.2mdv2009.1
lib64wxPythonGTK2.8-2.8.9.2-2mdv2009.1
lib64wxPythonGTK2.8-devel-2.8.9.2-2mdv2009.1
wxPythonGTK-2.8.9.2-2mdv2009.1
wxPythonGTK-tools-2.8.9.2-2mdv2009.1
wxPythonGTK-wxversion-2.8.9.2-2mdv2009.1
on a 64bit Mandriva box. AFAIK I am not the only one with this
problem.
Markus
