[GRASS-dev] [GRASS GIS] #1026: Problems starting grass7 from tcsh
trac at osgeo.org
Thu Apr 1 05:29:23 EDT 2010
Reporter: huhabla | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: default | Version: svn-trunk
Keywords: tcsh | Platform: Linux
Cpu: x86-32 |
I am unable to start grass from tcsh.
The following error occurs:
File "../../dist.i686-pc-linux-gnu/grass70.tmp", line 941, in <module>
csh_startup()
File "../../dist.i686-pc-linux-gnu/grass70.tmp", line 670, in
csh_startup
mail_re = re.compile(r"^ *set *mail *= *")
NameError: global name 're' is not defined
This may be related to a missing regular expression module import?
import re
will fix the bug on my system.
Getting grass7 started in a tcsh using the fix above and trying to start
the gui result in an error:
> r.info
No protocol specified
Unable to access the X Display, is $DISPLAY set properly?
> echo $DISPLAY
:0
Ticket URL: <http://trac.osgeo.org/grass/ticket/1026>
