[GRASS-dev] Re: [GRASS GIS] #1026: Problems starting grass7 from
tcsh
trac at osgeo.org
Thu Apr 1 17:31:07 EDT 2010
#1026: Problems starting grass7 from tcsh
Reporter: huhabla | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: default | Version: svn-trunk
Resolution: | Keywords: tcsh
Platform: Linux | Cpu: x86-32
Comment (by glynn):
Replying to [ticket:1026 huhabla]:
> I am unable to start grass from tcsh.
> The following error occurs:
mail_re = re.compile(r"^ *set *mail *= *")
NameError: global name 're' is not defined
> This may be related to a missing regular expression module import?
Yep. This should be fixed by r41652.
> Getting grass7 started in a tcsh using the fix above and trying to start
the gui result in an error:
> r.info
No protocol specified
Unable to access the X Display, is $DISPLAY set properly?
> echo $DISPLAY
:0
This is a separate issue. However, you might try:
export DISPLAY=unix:0
If that fixes it, it would appear to be an issue with your version of
wxWidgets (possibly using xcb directly rather than Xlib?).
Ticket URL: <http://trac.osgeo.org/grass/ticket/1026#comment:1>
