[GRASS-dev] Re: [GRASS GIS] #928: 6.4: wx module GUIs never return
trac at osgeo.org
Thu Apr 8 04:09:12 EDT 2010
Reporter: hamish | Owner: martinl
Type: defect | Status: assigned
Priority: critical | Milestone: 6.4.0
Component: default | Version: svn-releasebranch64
Resolution: | Keywords: addons
Platform: Linux | Cpu: x86-64
Comment (by hamish):
Replying to [comment:16 marisn]:
> Also g.gui -u wxpython has no effect on modules launched from
> CMD - I still get tcltk GUI afterwards. g.gisenv displays
> "GRASS_GUI=wxpython"
that is due to the way that the icons/menu items are set up on WinGrass.
If you look at the Properties they actually call "`grass64 -tcltk`" and
"`grass64 -wxpython`". Which has the effect of making the selection
permanent. Solution: if you want the tcltk gui click on the tcltk menu
item, if you want the wx gui click on the wx gui menu item. copy either
one to your desktop as desired.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/928#comment:17>
