[GRASS-dev] Re: [GRASS GIS] #1006: r.terraflow fails to stat()
stream file on Windows
trac at osgeo.org
Thu Apr 8 04:12:37 EDT 2010
#1006: r.terraflow fails to stat() stream file on Windows
Reporter: marisn | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: critical | Milestone: 6.4.0
Component: Raster | Version: svn-releasebranch64
Resolution: | Keywords: wxgui, wingrass, terraflow
Platform: MSWindows Vista | Cpu: x86-32
Comment (by marisn):
WinGRASS-6.4.SVN-r41749-1 running Vista with DEBUG=3:
GRASS 6.4.0svn (spearfish60)> r.terraflow --verbose
elevation=elevation.dem at PERM
ANENT filled=elevflood direction=elevdir swatershed=elevsinkwater
accumulation=e
levflowacc tci=elevtci memory=900
D2/3: G__read_Cell_head
D2/3: G__read_Cell_head_array
D3/3: region item: proj: 1
D3/3: region item: zone: 13
D3/3: region item: north: 4928010
D3/3: region item: south: 4913700
D3/3: region item: east: 609000
D3/3: region item: west: 589980
D3/3: region item: cols: 634
D3/3: region item: rows: 477
D3/3: region item: e-w resol: 30
D3/3: region item: n-s resol: 30
D3/3: region item: top: 1
D3/3: region item: bottom: 0
D3/3: region item: cols3: 634
D3/3: region item: rows3: 477
D3/3: region item: depths: 1
D3/3: region item: e-w resol3: 30
D3/3: region item: n-s resol3: 30
D3/3: region item: t-b resol: 1
D3/3: region item: north: 4928000
D3/3: region item: south: 4914020
D3/3: region item: west: 590010
D3/3: region item: cols: 633
D3/3: region item: rows: 466
D3/3: region item: format: 1
D3/3: region item: compressed: 1
cell elevation.dem header compatible with region header
Elevation stored as FLOAT (4B)
BR╬DIN┬JUMS:raster elevation.dem is of type CELL_TYPE --you should use
r.terraflow.short
Region size is 477 x 634
STREAM temporary files in C:/Users/Maris/AppData/Local/Temp (THESE
INTERMEDIATE
STREAMS WILL NOT BE DELETED IN CASE OF ABNORMAL TERMINATION OF THE
PROGRAM. TO
SAVE SPACE PLEASE DELETE THESE FILES MANUALLY!)
stats.out: Permission denied
Ticket URL: <http://trac.osgeo.org/grass/ticket/1006#comment:21>
