[GRASS-dev] [GRASS GIS] #1031: More specific parameter information in command line help
GRASS GIS trac at osgeo.org
Thu Apr 8 10:23:22 EDT 2010
 Reporter:  huhabla       |       Owner:  grass-dev at lists.osgeo.org
     Type:  enhancement   |      Status:  new
 Priority:  minor         |   Milestone:  7.0.0
Component:  libgis        |     Version:  svn-trunk
 Keywords:  parser, help  |    Platform:  All
      Cpu:  All           |
 I would like to suggest the implementation of a more informative command
 line help for grass modules. Additionally to the current parameters the
 status(age), type and if it is required or not should be displayed.
 A patch for parser_help.c is attached.
 Example r.buffer:
 lib/gis>r.buffer help
 Description:
  Creates a raster map layer showing buffer zones surrounding cells that
 contain non-NULL category values.
 Keywords:
  raster, buffer
 Usage:
  r.buffer [-z] input=name output=name distances=value[,value,...]
    [units=string] [--overwrite] [--verbose] [--quiet]
 Flags:
   -z   Ignore zero (0) data cells instead of NULL cells
  --o   Allow output files to overwrite existing files
  --v   Verbose module output
  --q   Quiet module output
 Parameters:
       input   Name of input raster map
      output   Name for output raster map
   distances   Distance zone(s)
       units   Units of distance
               options: meters,kilometers,feet,miles,nautmiles
               default: meters
 Will change into
 lib/gis> r.buffer help
 Description:
 Keywords:
  raster, buffer
 Usage:
 Flags:
 Parameters:
               status: input
               type: cell
               required: yes
               status: output
               type: cell
               required: yes
               type: float
               required: yes
               default: meters
               type: string
               required: no
Ticket URL: <http://trac.osgeo.org/grass/ticket/1031>
