[GRASS-dev] Re: [GRASS GIS] #1031: More specific parameter
information in command line help
trac at osgeo.org
Fri Apr 9 06:26:13 EDT 2010
#1031: More specific parameter information in command line help
Reporter: huhabla | Owner: grass-dev at lists.osgeo.org
Type: enhancement | Status: new
Priority: minor | Milestone: 7.0.0
Component: libgis | Version: svn-trunk
Resolution: | Keywords: parser, help
Platform: All | Cpu: All
Comment (by hamish):
most of what you want is already given by usage:
Usage:
r.buffer [-z] input=name output=name distances=value[,value,...]
[units=string] [--overwrite] [--verbose] [--quiet]
things in [square] brackets are optional (according to age-old unix
convention (and prob ms-dos too))
the 'name' or 'value' on the right side of the equals sign, if not given a
custom setting by the programmer with opt->key_desc, could perhaps be
improved. see the tcltk module guis which are quite informative. I think
we still have some work to do on this for the wx module guis (see also
#886 for that).
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1031#comment:1>
