[GRASS-dev] Re: [SoC] Improve multicriteria analysis tools (porting add-on to GRASS7)
Jean-Denis Giguere jdenisgiguere at gmail.com
Thu Apr 8 19:30:02 EDT 2010
Thank you very much Markus!
Following your instructions, the modification was mostly straightforward.
I also needed to add $(RASTERLIB) to LIBES and  $(RASTERDEP) to
DEPENDENCIES in the Makefile.
Since I didn't test well the whole thing, I set up a mercurial
repository. Interested people may follow development at
http://bitbucket.org/jdenisgiguere/grass-mcda/
Regards,
2010/4/5 Markus Neteler <neteler at osgeo.org>:
> On Mon, Apr 5, 2010 at 9:25 PM, Jean-Denis Giguere
> <jdenisgiguere at gmail.com> wrote:
>> It seems to have many changes in raster modules between GRASS6 and
>> GRASS7. I would like to know if I can find documentation about porting
>> GRASS6 add-on to GRASS7.
> It requires several updates to the new raster library architecture.
> Basically, the "raster.h" header must be added and functions renamed,
> for example
>  G_put_raster_row() -> Rast_put_row()
> etc.
> For an overview table, see
>  http://trac.osgeo.org/grass/wiki/Grass7/RasterLib/ListOfFunctions
> A good idea is also to compare modules between GRASS 6.5 and 7.
> Best
> Markus
