[GRASS-dev] Re: [GRASS GIS] #1032: ErrorCommandExecution g.proj
trac at osgeo.org
Sat Apr 10 10:07:49 EDT 2010
Reporter: sallar | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: blocker | Milestone: 6.4.0
Component: default | Version: 6.4.0 RCs
Resolution: | Keywords: g.proj
Platform: Linux | Cpu: x86-32
Comment (by sallar):
Replying to [comment:6 martinl]:
> Please run
> gdb g.proj
> run -p
> instead.
I get this:
GRASS 6.4.0RC6 (PIT):~ > gdb g.proj
GNU gdb 6.8-debian
Copyright (C) 2008 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later
<http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law. Type "show copying"
and "show warranty" for details.
This GDB was configured as "i486-linux-gnu"...
(gdb) run -p
Starting program: /usr/local/grass-6.4.0RC6/bin/g.proj -p
[Thread debugging using libthread_db enabled]
D2/5: G__read_Cell_head
D2/5: G__read_Cell_head_array
D3/5: region item: proj: 0
D3/5: region item: zone: 0
D3/5: region item: north: 4526334.08251007
D3/5: region item: south: 4474101.25111007
D3/5: region item: east: 563815.12526504
D3/5: region item: west: 528349.01576504
D3/5: region item: cols: 20
D3/5: region item: rows: 20
D3/5: region item: e-w resol: 1773.305475
D3/5: region item: n-s resol: 2611.64157
D3/5: region item: top: 1
D3/5: region item: bottom: 0
D3/5: region item: cols3: 20
D3/5: region item: rows3: 20
D3/5: region item: depths: 1
D3/5: region item: e-w resol3: 1773.305475
D3/5: region item: n-s resol3: 2611.64157
D3/5: region item: t-b resol: 1
XY location (unprojected)
*** glibc detected *** /usr/local/grass-6.4.0RC6/bin/g.proj: double free
or corruption (fasttop): 0x0804e510 ***
[New Thread 0xb6e036d0 (LWP 10727)]
======= Backtrace: =========
/lib/i686/cmov/libc.so.6[0xb7802624]
/lib/i686/cmov/libc.so.6(cfree+0x96)[0xb7804826]
/usr/lib/libstdc++.so.6(_ZdlPv+0x21)[0xb74802e1]
/usr/lib/libstdc++.so.6(_ZNSs4_Rep10_M_destroyERKSaIcE+0x1d)[0xb745cb2d]
/usr/lib/libstdc++.so.6(_ZNSsD1Ev+0x51)[0xb745e501]
/lib/i686/cmov/libc.so.6(__cxa_finalize+0xc1)[0xb77c2e51]
/usr/lib/libgeos-3.1.0.so[0xb72d4dc4]
/usr/lib/libgeos-3.1.0.so[0xb737dcd0]
/lib/ld-linux.so.2[0xb7f02453]
/lib/i686/cmov/libc.so.6(exit+0x89)[0xb77c2ab9]
/usr/local/grass-6.4.0RC6/bin/g.proj(main+0x3d2)[0x804a7d2]
/lib/i686/cmov/libc.so.6(__libc_start_main+0xe5)[0xb77aa455]
/usr/local/grass-6.4.0RC6/bin/g.proj[0x8049a21]
======= Memory map: ========
08048000-0804c000 r-xp 00000000 03:03 1164337
0804c000-0804d000 rw-p 00004000 03:03 1164337
0804d000-0806e000 rw-p 0804d000 00:00 0 [heap]
b6d00000-b6d21000 rw-p b6d00000 00:00 0
b6d21000-b6e00000 ---p b6d21000 00:00 0
b6e03000-b6e06000 rw-p b6e03000 00:00 0
b6e06000-b6e6c000 r-xp 00000000 03:03 819183
/usr/lib/libgcrypt.so.11.4.4
b6e6c000-b6e6e000 rw-p 00066000 03:03 819183
b6e6e000-b6e71000 r-xp 00000000 03:03 818510 /usr/lib/libgpg-
error.so.0.3.0
b6e71000-b6e72000 rw-p 00002000 03:03 818510 /usr/lib/libgpg-
error.so.0.3.0
b6e72000-b6e81000 r-xp 00000000 03:03 818452
/usr/lib/libtasn1.so.3.0.15
b6e81000-b6e82000 rw-p 0000e000 03:03 818452
b6e82000-b6f19000 r-xp 00000000 03:03 818764
/usr/lib/libgnutls.so.26.4.6
b6f19000-b6f1f000 rw-p 00097000 03:03 818764
b6f1f000-b6f20000 rw-p b6f1f000 00:00 0
b6f20000-b6f36000 r-xp 00000000 03:03 817192
/usr/lib/libsasl2.so.2.0.22
b6f36000-b6f37000 rw-p 00015000 03:03 817192
b6f37000-b6f43000 r-xp 00000000 03:03 817395
/usr/lib/liblber-2.4.so.2.1.0
b6f43000-b6f44000 rw-p 0000c000 03:03 817395
b6f44000-b6f54000 r-xp 00000000 03:03 51464
/lib/i686/cmov/libresolv-2.7.so
b6f54000-b6f56000 rw-p 0000f000 03:03 51464
b6f56000-b6f58000 rw-p b6f56000 00:00 0
b6f58000-b6f5a000 r-xp 00000000 03:03 32806 /lib/libkeyutils-1.2.so
b6f5a000-b6f5b000 rw-p 00001000 03:03 32806 /lib/libkeyutils-1.2.so
b6f5b000-b6f62000 r-xp 00000000 03:03 277767
/usr/lib/libkrb5support.so.0.1
b6f62000-b6f63000 rw-p 00006000 03:03 277767
b6f63000-b6f64000 rw-p b6f63000 00:00 0
b6f64000-b6f87000 r-xp 00000000 03:03 277757
/usr/lib/libk5crypto.so.3.1
b6f87000-b6f88000 rw-p 00023000 03:03 277757
b6f88000-b6f9d000 r-xp 00000000 03:03 51453
/lib/i686/cmov/libpthread-2.7.so
b6f9d000-b6f9f000 rw-p 00014000 03:03 51453
b6f9f000-b6fa1000 rw-p b6f9f000 00:00 0
b6fa1000-b6fe1000 r-xp 00000000 03:03 817426
/usr/lib/libldap_r-2.4.so.2.1.0
b6fe1000-b6fe3000 rw-p 0003f000 03:03 817426
b6fe3000-b6fe4000 rw-p b6fe3000 00:00 0
b6fe4000-b6fed000 r-xp 00000000 03:03 50035
/lib/i686/cmov/libcrypt-2.7.so
b6fed000-b6fef000 rw-p 00008000 03:03 50035
b6fef000-b7016000 rw-p b6fef000 00:00 0
b7016000-b703f000 r-xp 00000000 03:03 277751
/usr/lib/libgssapi_krb5.so.2.2
b703f000-b7040000 rw-p 00028000 03:03 277751
b7040000-b7041000 rw-p b7040000 00:00 0
b7041000-b7043000 r-xp 00000000 03:03 32652 /lib/libcom_err.so.2.1
b7043000-b7044000 rw-p 00001000 03:03 32652 /lib/libcom_err.so.2.1
b7044000-b70d6000 r-xp 00000000 03:03 277766 /usr/lib/libkrb5.so.3.3
b70d6000-b70d8000 rw-p 00092000 03:03 277766 /usr/lib/libkrb5.so.3.3
b70d8000-b7212000 r-xp 00000000 03:03 1354596
/usr/lib/i686/cmov/libcrypto.so.0.9.8
b7212000-b7228000 rw-p 0013a000 03:03 1354596
b7228000-b722b000 rw-p b7
Program received signal SIGABRT, Aborted.
[Switching to Thread 0xb6e036d0 (LWP 10727)]
0xb7ef3424 in __kernel_vsyscall ()
(gdb)
Ticket URL: <http://trac.osgeo.org/grass/ticket/1032#comment:7>
