[GRASS-dev] Re: [GRASS GIS] #1032: ErrorCommandExecution g.proj
GRASS GIS trac at osgeo.org
Sat Apr 10 10:47:28 EDT 2010
  Reporter:  sallar   |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect   |      Status:  new
  Priority:  blocker  |   Milestone:  6.4.0
 Component:  default  |     Version:  6.4.0 RCs
Resolution:           |    Keywords:  g.proj
  Platform:  Linux    |         Cpu:  x86-32
Comment (by hamish):
 ... and then type "bt full" at the (gdb) prompt after it breaks.
 did you install from pre-packaged binaries or self-compile? which linux
 distro/version? (smells like a recent ubuntu) If it's a binary install,
 where did you get the binaries from?
 AFAICT the only thing it could be is this in g.proj/main.c,
     if (projinfo != NULL)
         G_free_key_value(projinfo);
     if (projunits != NULL)
         G_free_key_value(projunits);
 but I'm not sure how that could happen as your debug message shows region
 proj:0. If you built from source could you try to rebuild, running "make
 distclean" before ./configure?
 Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/1032#comment:8>
