[GRASS-dev] Re: [GRASS GIS] #1031: More specific parameter
information in command line help
trac at osgeo.org
Tue Apr 13 19:08:47 EDT 2010
#1031: More specific parameter information in command line help
Reporter: huhabla | Owner: grass-dev at lists.osgeo.org
Type: enhancement | Status: new
Priority: minor | Milestone: 7.0.0
Component: libgis | Version: svn-trunk
Resolution: | Keywords: parser, help
Platform: All | Cpu: All
Comment (by huhabla):
Replying to [comment:9 glynn]:
> Replying to [comment:7 martinl]:
> > Probably we should think about the optimalization of the attributes in
struct Option
> Yes please.
> I've been suggesting that the "type system" should be re-worked since
roughly forever. I would have hoped that the wxGUI development would
produce some feedback, but so far that hasn't happened.
Reworking the "type system" is a good idea. I would be happy to help. My
main focus is that most of the data processing grass modules supports the
generation of a fully machine readable description of its inputs and
outputs (raster, vector, file ... as well as literal data).
This will allow the automated generic connection of modules in graphical
work-flow builder as well as in WPS process builder.
The current approach leads in the right direction but could e improved.
E.g.: putting the age, element and prompt into the gisprompt string may be
replaced using functions like G_option_set_age(), G_option_set_element()
and so on. So the Option structure can be enhanced with additional
variables, which are accessed with library functions, so better parameter
storage schemes may be implemented and data handling is easier (no parsing
overhead)?
From the WPS describe process point of view, i need the following
variables:
key Identifier in WPS execute request
multiple maxOccurs in WPS execute request
description and label abstract and title for inputs and outputs
age Is used to distinguish between old -> input
(ComplexData, LiteralData) and new -> output (ComplexOutput,
LiteralOutput)
required minOccurs in WPS execute request
answer Default value
options Allowed values
prompt Is used to distinguish between raster, vector and
file
type LiteralData type
Additionally the following parameter would be very useful:
* The mime types of input and output files
* The specification of multiple outputs see #1033
* In case no output was defined (e.g. r.univar) the definition of the data
type printed to stdout is useful. There is currently no way to define the
literal data type of printed output ... and may never be, because this
mostly depends on flags or different options
Ticket URL: <http://trac.osgeo.org/grass/ticket/1031#comment:11>
