[GRASS-dev] Re: [GRASS GIS] #1031: More specific parameter
information in command line help
trac at osgeo.org
Wed Apr 14 14:46:19 EDT 2010
#1031: More specific parameter information in command line help
Reporter: huhabla | Owner: grass-dev at lists.osgeo.org
Type: enhancement | Status: new
Priority: minor | Milestone: 7.0.0
Component: libgis | Version: svn-trunk
Resolution: | Keywords: parser, help
Platform: All | Cpu: All
Comment (by martinl):
Replying to [comment:4 huhabla]:
> > > Martin Landa currently renamed in several modules the input and
output parameter to make clear which of them are inputs or outputs. I.e:
elevation -> elevation_input, direction -> direction_output, but this is
IMHO not a good idea. It is redundant information, especially if you are
using the gui.
> > Right, see [wiki:Grass7/NewFeatures#Renamedoptions Rename options].
Your idea about 'status' info seems to be better solution. If you prefer I
can remove '_input/optput' from paramaters key string.
> Well this is only my humble opinion. In case other developers prefer the
your naming schema i will accept it. Thats why i would like to discuss
this topic.
> I would personally prefer to remove '_input/optput' from paramaters key
string and establish a combination of {{{key_desc}}} and the additional
"status" parameter in the command line. Maybe we can use a better name
than "status" ... like "type"? Additionally we can hide the status
parameter in case "input", "map" and "output" are used as {{{key}}}
strings?
OK, done in r41865, [wiki:Grass7/NewFeatures#Renamedoptions Rename
options] updated.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1031#comment:12>
