[GRASS-dev] [SoC] Parallelization of Raster and Vector modules
Yann Chemin
yann.chemin at gmail.com
Wed Apr 14 23:50:35 EDT 2010
Hello,
was wondering if the actual raster library API could be extended to
read/write a given n contiguous number of lines in a buffer instead of
a single one? This maybe of help for parallelization...
Regards,
Yann
On 4 April 2010 11:22, Jordan Neumeyer <jordan.neumeyer at mines.sdsmt.edu> wrote:
> On Thu, Apr 1, 2010 at 3:24 PM, Glynn Clements <glynn at gclements.plus.com>
> wrote:
>> Jordan Neumeyer wrote:
>> > > > Just kind of my thought process about how I would try to go about
>> > > > parallelizing a module.
>> > > The main issue with parallelising raster input is that the library
>> > > keeps a copy of the current row's data, so that consecutive reads of
>> > > the same row (as happen when upsampling) don't re-read the data.
>> > > For concurrent access to a single map, you would need to either keep
>> > > one row per thread, or abandon caching. Also, you would need to use
>> > > pread() rather than fseek()+read().
>> > It sounds like you're talking about parallelism in I/O from a file or
>> > database. Neither of which is my intent or goal for this project. I will
>> > parallelize things after they have already been read into memory, and
>> > tasks
>> > are processor intensive. I wouldn't want parallelize any I/O, but if I
>> > were
>> > to optimize I/O. I would make all operations I/O asynchronous, which is
>> > can
>> > mimic parallelism in a sense. Queuing up the chunks of data and then
>> > processing them as resources become available.
>> Most GRASS raster modules process data row-by-row, rather than reading
>> entire maps into memory. Reading maps into memory is frowned upon, as
>> GRASS is regularly used with maps which are too large to fit into
>> memory. Where the algorithm cannot operate row-by-row, use of a tile
>> cache is the next best alternative; see e.g. r.proj.seg (renamed to
>> r.proj in 7.0).
> That makes more sense. So a row is like chunk from the map data? Kind of
> like the first row of pixels from an image. So from the first pixel to width
> of image is one row, then width plus one starts the next, and so on and so
> forth. How large are the rows generally?
>> Holding an entire map in memory is only considered acceptable if the
>> algorithm is inherently so slow that processing a gigabyte-sized map
>> simply wouldn't be feasible, or the access pattern is such that even a
>> tile-cache approach isn't feasible.
>> In general, GRASS should be able to process multi-gigabyte maps even
>> on 32-bit systems, and work on multi-user systems where a process
>> cannot assume that it can use a significant proportion of the system's
>> total physical memory.
> Which is good. I didn't realize how big the data set could be. What's
> biggest map you've seen?
>> > > It's more straightfoward to read multiple maps concurrently. In 7.0,
>> > > this case should be thread-safe.
>> > > Alternatively, you could have one thread for reading, one for writing,
>> > > and multiple worker threads for the actual processing. However, unless
>> > > the processing is complex, I/O will be the bottleneck.
>> > I/O is generally a bottleneck anyway. Something always tends to be
>> > waiting
>> > on another.
>> When I refer to I/O, I'm referring not just to read() and write(), but
>> also the (de)compression, conversion and resampling, i.e. everything
>> performed by the get/put-row functions. For many GRASS modules, this
>> takes more time than the actual processing.
> I can see why, especially for big maps since it's doing that row-by-row.
> So when a GRASS module loads a map the basic algorithm looks something like:
> 1) Read row
> 2) get-row function does necessary preprocessing
> 3) row is cached or held in memory. Does the caching take place after
> 4) row is processed
> 5) Display/write process ? (Or is this after a couple iterations, all of
> them?)
> 5) repeat (1)
> Would it be beneficial/practical to parallelize some of the preprocessing
> like conversion and resampling before the caching occurs?
>> Finally, the thread title refers to libraries. Very little processing
>> occurs in the libraries; most of it is in the individual modules. So
>> there isn't much scope for "parallelising" the libraries. The main
>> issue for library functions is to ensure that they are thread-safe.
>> Most of the necessary work for the raster library has been done in
>> 7.0.
> I was trying to refer to all of the raster modules as a whole, but library
> is just what the modules share. I've changed the title from Parallelization
> of Raster and Vector libraries to Parallelization of Raster and Vector
> modules.
> Would I be working on GRASS 6.x or 7.x? Is there a minimum compiler version
> when using GCC/MingW? Just curious because openMP tasks are only supported
> on GCC >= 4.2. Which may or not be useful, but can be a valuable tool when
> you don't know how much data or how many "tasks" you have. Like processing a
> linked-list or binary trees.
> ~Jordan
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
Yann Chemin
Senior Spatial Hydrologist
www.csu.edu.au/research/icwater
M +61-4-3740 7019
