[GRASS-dev] v.external, ogr direct access,
topology and pseudo-topology.... a bit confused
Moritz Lennert
mlennert at club.worldonline.be
Mon Apr 19 15:55:41 EDT 2010
Jumping into the debate, since it raises some fundamental questions in
my eyes;
On 19/04/10 17:46, G. Allegri wrote:
> No problem, this is not what I expect. I just expect a user to be able
> to import a polygonal layer, without worrying about topology correctness
> (clean/build operations), and do spatial operations on it. Obviously the
> correctness of results depend on the operation the user is doing (and
> it's his problem) but, i.e. a geometrical clip will be always correct, I
> think...
The questions here for me are:
- What is the actual error linked to doing operations on non-topological
formats ?
- Why do you absolutely want GRASS to do this ? If all you want to do is
simple geometry operations on spaghetti files, you can easily do this
with most of the available open source viewers / GIS, such as QGIS,
gvSIG, uDIG, etc or even directly with ogr. Why go through the trouble
of using GRASS for that ?
>> These operations should be quite fast for native vectors with topology.
> With "rapidly" I meant: load data, do-the-op, save the results. I'm sure
> that the native grass data structures can deal more efficiently then SF
> structures.... but often a user prefer to wait a minute more for the
> operation to end, then working a minute to have to manage the data
> cleaness (more often it takes much more then a minute, and it doesn't
> worth it!)
> > Yes, although not that rapidly because pseudo-topology needs to be
> built first. Polygons do not need to be clean, but then nobody can
> guarantee for the results.
> Ok, but the user just have to wait and wath the progress bar
> completing... that's ok from his perspective :)
I find it a bit suspicious when user comfort is apparently put so much
higher in priority then correctness of results...
Moritz
