[GRASS-dev] Re: [GRASS GIS] #657: add --with-openmp support to
./configure
trac at osgeo.org
Wed Apr 21 15:17:24 EDT 2010
#657: add --with-openmp support to ./configure
Reporter: hamish | Owner: grass-dev at lists.osgeo.org
Type: task | Status: new
Priority: normal | Milestone: 7.0.0
Component: Compiling | Version: svn-trunk
Resolution: | Keywords: openmp
Platform: All | Cpu: All
Comment (by glynn):
Replying to [comment:1 hamish]:
> wrt trunk/lib/gpde/Makefile, does -lgomp have to be before $(GMATHLIB)
and -lm or could we do
> EXTRA_LIBS += -lgomp
> later?
lib/gpde/Makefile should just have $(OMPLIB) at the appropriate place in
EXTRALIBS, probably immediately before $(MATHLIB).
> should we do the same "+=" trick for EXTRA_CFLAGS=-fopenmp, to stop it
from clobbering any earlier setting?
EXTRA_CFLAGS = $(OMPCFLAGS)
Once the configure checks are written, Platform.make.in would define
these. Until then, you can use e.g.
make OMPCFLAGS=-fopenmp OMPLIB=-lgomp ...
Ticket URL: <https://trac.osgeo.org/grass/ticket/657#comment:3>
