[GRASS-dev] Re: [GRASS GIS] #1042: winGRASS: r.statistics complains if path to grassdb has spaces
GRASS GIS trac at osgeo.org
Thu Apr 22 13:23:00 EDT 2010
  Reporter:  ege           |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect        |      Status:  new
  Priority:  normal        |   Milestone:  6.4.0
 Component:  Raster        |     Version:  svn-releasebranch64
Resolution:                |    Keywords:  wingrass
  Platform:  MSWindows XP  |         Cpu:  x86-32
Comment (by glynn):
 Replying to [comment:5 neteler]:
 > Other candidates:
 d.barscale/main.c:      sprintf(cmdbuf, "%s bcolor=%s", cmdbuf,
 opt1->answer);
 d.barscale/main.c:      sprintf(cmdbuf, "%s tcolor=%s", cmdbuf,
 opt2->answer);
 The one before that might require it, i.e.:
         sprintf(cmdbuf, "\"%s\" at=%f,%f", argv[0], east, north);
 d.histogram/get_stats.c:        cmd = mk_command("r.stats -Cr%s%s \"%s\" >
 \"%s\"\n", 4,
 d.histogram/get_stats.c:        cmd = mk_command("r.stats -r%s%s \"%s\"
 nsteps=%s > \"%s\"\n", 5,
 r.average/main.c:    sprintf(command, "%s -anC input=%s,%s fs=space >
 \"%s\"",
 r.average/main.c:    sprintf(command, "%s input=%s output=%s < \"%s\"",
 These are already quoted sufficiently.
 d.profile/Range.c:    sprintf(stats_cmd, "r.stats -ci %s > %s\n", name,
 temp_fname);
 This needs quoting:
     sprintf(stats_cmd, "r.stats -ci %s > \"%s\"", name, temp_fname);
 d.text.new/main.c:    sprintf(buf, "%s < %s", G_recreate_command(),
 cmd_file);
 So does this:
     sprintf(buf, "%s < \"%s\"", G_recreate_command(), cmd_file);
 r.out.mpeg/main.c:      sprintf(cmd, "%s %s 2> /dev/null > /dev/null",
 encoder, mpfilename);
 r.out.mpeg/main.c:          sprintf(cmd, "cd %s; \\ls %s >> %s 2>
 /dev/null",
 xganim/main.c:      sprintf(cmd, "cd %s; \\ls %s >> %s 2> /dev/null",
 path, wildarg,
 And all of these; although, I don't think that gee_wildfiles() will work
 on Windows in any event, due to Unix-isms. 7.0 uses g.mlist via
 G_spawn_ex().
Ticket URL: <http://trac.osgeo.org/grass/ticket/1042#comment:6>
