[GRASS-dev] GDAL configuration for GRASS
António Rocha
antonio.rocha at deimos.com.pt
Fri Apr 23 09:07:01 EDT 2010
Hi Markus
Ahhh I have installed libgdal1-1.6.0-grass GRASS extension for the GDAL
library from Synaptic Package Manager a few months ago.. And I never got
any problem. What is this for? and what might be the problem from of
activating GRASS in GDAL (I believe haven't done this).
Markus Neteler wrote:
> 2010/4/23 António Rocha <antonio.rocha at deimos.com.pt>:
>> Greetings
>> I've been using GDAL installed by my Synaptic Package Manager. But now, due
>> to ORFEO ToolBox Restrictions I will have to recompile and install GDAL by
>> hand. Could anyone indicated me the minimum requirements/configuration for
>> GDAL in order to be used by GRASS?
> To my knowledge there are no restrictions at all. The minimum is to
> just launch
> ./configure ....
> of GDAL with everything set off (but not sure if it quite useful then).
> Important:
> Be sure to not activate GRASS in GDAL, use the plugin instead:
> http://grass.osgeo.org/wiki/Compile_and_install_GDAL-GRASS_plugin
> Markus
> __________ Information from ESET NOD32 Antivirus, version of virus signature database 5052 (20100423) __________
> The message was checked by ESET NOD32 Antivirus.
> http://www.eset.com
http://www.eset.com
