[GRASS-dev] r.fuzzy.system can someone check???
Jarek Jasiewicz jarekj at amu.edu.pl
Fri Apr 23 13:00:29 EDT 2010
Hi!
I have created month ago tool r.fuzzy.system...
I found yesterday that program works fine on 64 bit system (ubuntu) but
fails on 32 with segmentation fault.
Could someone with 32 bit and someone with 64 bit systems compile and
run program according example (necessary files are included in
directory) to check if this is true??
grateful for help
Jarek
