[GRASS-dev] r.fuzzy.system can someone check???
Maris Nartiss
maris.gis at gmail.com
Fri Apr 23 15:47:02 EDT 2010
Hello,
this module was running just fine on my ~AMD64 Gentoo, still Valgrind
was complaining a bit (no idea if it's harmfull in Your code):
Calculate...
0%==28214== Invalid read of size 4
==28214== at 0x402388: fuzzy (fuzzylogic.c:8)
==28214== by 0x405055: implicate (system.c:41)
==28214== by 0x4034C4: main (main.c:186)
==28214== Address 0x5e8e360 is not stack'd, malloc'd or (recently) free'd
==28214==
==28214== at 0x402393: fuzzy (fuzzylogic.c:10)
==28214== Address 0x5e8e364 is not stack'd, malloc'd or (recently) free'd
==28214==
16% 33% 50% 66% 83% 100%
Close...
Maris.
2010/4/23, Jarek Jasiewicz <jarekj at amu.edu.pl>:
> Hi!
> I have created month ago tool r.fuzzy.system...
> I found yesterday that program works fine on 64 bit system (ubuntu) but
> fails on 32 with segmentation fault.
> Could someone with 32 bit and someone with 64 bit systems compile and
> run program according example (necessary files are included in
> directory) to check if this is true??
> grateful for help
> Jarek
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
