[GRASS-dev] r.fuzzy.system can someone check???
Jarek Jasiewicz jarekj at amu.edu.pl
Sat Apr 24 01:45:50 EDT 2010
Maris Nartiss pisze:
> Hello,
> this module was running just fine on my ~AMD64 Gentoo, still Valgrind
> was complaining a bit (no idea if it's harmfull in Your code):
> Calculate...
>    0%==28214== Invalid read of size 4
> ==28214==    at 0x402388: fuzzy (fuzzylogic.c:8)
> ==28214==    by 0x405055: implicate (system.c:41)
> ==28214==    by 0x4034C4: main (main.c:186)
> ==28214==  Address 0x5e8e360 is not stack'd, malloc'd or (recently) free'd
> ==28214==
> ==28214==    at 0x402393: fuzzy (fuzzylogic.c:10)
> ==28214==  Address 0x5e8e364 is not stack'd, malloc'd or (recently) free'd
> ==28214==
>   16%  33%  50%  66%  83% 100%
> Close...
> Maris.
Thanks Maris,
 this is that which cause segment fault 32 bit, thanks very much
The problem Is I do not know how to fix it....
many thanks
Jarek
> 2010/4/23, Jarek Jasiewicz <jarekj at amu.edu.pl>:
>> Hi!
>> I have created month ago tool r.fuzzy.system...
>> I found yesterday that program works fine on 64 bit system (ubuntu) but
>> fails on 32 with segmentation fault.
>> Could someone with 32 bit and someone with 64 bit systems compile and
>> run program according example (necessary files are included in
>> directory) to check if this is true??
>> grateful for help
>> Jarek
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
