[GRASS-dev] 6.4.0 blocker bugs
Tue Aug 10 12:31:56 EDT 2010
Martin Landa wrote:
> > I'd like to just make one final request to remove the swig directory
> > before release. Otherwise, people will try and use it.
> I would vote for it. The wxGUI vdigit and nviz has been disabled,
> there is nothing which uses swig.
Even if they were enabled, vdigit and (the SWIG-based version of) nviz
don't use anything from the swig directory.
