[GRASS-dev] 6.4.0 blocker bugs
Markus Neteler neteler at osgeo.org
Wed Aug 11 04:51:13 EDT 2010
On Tue, Aug 10, 2010 at 6:31 PM, Glynn Clements
<glynn at gclements.plus.com> wrote:
> Martin Landa wrote:
>> > I'd like to just make one final request to remove the swig directory
>> > before release. Otherwise, people will try and use it.
Good point.
>> I would vote for it. The wxGUI vdigit and nviz has been disabled,
>> there is nothing which uses swig.
> Even if they were enabled, vdigit and (the SWIG-based version of) nviz
> don't use anything from the swig directory.
I see that the ctypes backport consists of two commits:
http://trac.osgeo.org/grass/changeset/42916
http://trac.osgeo.org/grass/changeset/43015
No patch problems with
patch -p4 < changeset_r42916.diff
Nor compilation issues after:
cd lib/python/ctypes/
chmod a+x ctypesgen.py
Question: side-effects to be expected?
Markus
PS: perhaps we should move
swig/python/examples
elsewhere.
