[GRASS-dev] About v.distance, v.what.vect (wrt "count points within...").
Martin Landa landa.martin at gmail.com
Fri Aug 13 02:14:50 EDT 2010
2010/8/13 Nikos Alexandris <nikos.alexandris at felis.uni-freiburg.de>:
>> --- v.db.dropcolumn.py  2010-08-12 18:48:03.000000000 +0200
>> +++ /home/mlennert/v.db.dropcolumn.py   2010-08-12 18:47:29.000000000 +0200
>> @@ -102,6 +102,7 @@
>>              "DROP TABLE ${table}",
>>              "CREATE TABLE ${table}(${coldef})",
>>              "INSERT INTO ${table} SELECT ${colnames} FROM ${table}_backup",
>> +           "CREATE UNIQUE INDEX ${table}_cat ON ${table ( ${keycol} )"
> +              "CREATE UNIQUE INDEX ${table}_cat ON ${table ( ${keycol} )" ,
> #missing comma?
>>              "DROP TABLE ${table}_backup",
>>              "COMMIT"
>    sql = tmpl.substitute(table = table, coldef = coltypes, colnames =
> colnames)
change to
colnames, keycol = keycol)
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
