[GRASS-dev] About v.distance, v.what.vect (wrt "count points within...").
Nikos Alexandris nikos.alexandris at felis.uni-freiburg.de
Fri Aug 13 02:47:54 EDT 2010
Moritz L:
> >> --- v.db.dropcolumn.py  2010-08-12 18:48:03.000000000 +0200
> >> +++ /home/mlennert/v.db.dropcolumn.py   2010-08-12 18:47:29.000000000
> >> +0200 @@ -102,6 +102,7 @@
> >>              "DROP TABLE ${table}",
> >>              "CREATE TABLE ${table}(${coldef})",
> >>              "INSERT INTO ${table} SELECT ${colnames} FROM
> >> ${table}_backup", +           "CREATE UNIQUE INDEX ${table}_cat ON
> >> ${table ( ${keycol} )"
Nikos A:
> > +              "CREATE UNIQUE INDEX ${table}_cat ON ${table ( ${keycol}
> > )" , #missing comma?
> >>              "DROP TABLE ${table}_backup",
> >>              "COMMIT"
> >    sql = tmpl.substitute(table = table, coldef = coltypes, colnames =
> > colnames)
Martin L:
> change to
> colnames, keycol = keycol)
Everything works fine now in grass_trunk, that is:
a. "v.db.dropcolumn" on its own
b. "v.distance" is fast even after dropping a column (=index is there)
Nikos (happy user today) :D
