[GRASS-dev] Re: [GRASS GIS] #1131: Global LFS for wingrass
trac at osgeo.org
Fri Aug 13 14:30:27 EDT 2010
Reporter: mmetz | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 7.0.0
Component: libgis | Version: svn-trunk
Keywords: LFS,wingrass | Platform: MSWindows 7
Cpu: All |
Comment(by glynn):
Replying to [comment:1 mmetz]:
> Following up previous discussions, I have removed struct stat where
possible. The changes needed for LFS with wingrass are in config.h.in but
still inactive.
> Glynn, could you please check if I messed up something somewhere (all
the struct stat related changes and config.h.in)?
The config.h.in changes seem okay. Although, I would omit the aliases for
seek() and tell(), as we don't use those (does seek() even exist? I can't
find any evidence for it).
I don't see any "struct stat" changes. Currently, 7.0 has references to
"struct stat" in:
display/d.font/main.c
general/g.access/get_perms.c
general/g.mkfontcap/freetype_fonts.c
include/gisdefs.h
include/iostream/ami_stream.h
lib/db/dbmi_base/isdir.c
lib/gis/copy_dir.c
lib/gis/mapset_msc.c
lib/gis/mapset_nme.c
lib/gis/paths.c
lib/gis/remove.c
lib/gis/user_config.c
lib/init/clean_temp.c
lib/vector/Vlib/open.c
lib/vector/dglib/examples/parse.c
lib/vector/diglib/file.c
raster/r.li/r.li.daemon/daemon.c
vector/v.mapcalc/map.c
Ticket URL: <http://trac.osgeo.org/grass/ticket/1131#comment:2>
